BRIEFCASEMANX
Winner chicken dinner!
Ford Van said:I am just a guy who doesn't think he is smarter than the facts.![]()
that was a sweet rant. I rate it a 9.
So a shift in time is equivalent to a change in the initial phase. Conversely, a change in the initial phase is tantamount to a shift in time.
Diffusion said:oh. so basically I just shouldnt fuck with it when im recording?
The electronic phasing effect is created by splitting an audio signal into two, electronically shifting the phase of one signal (usually by passing it through an allpass filter), and then recombining the two signals. The allpass filter passes all frequencies unchanged in amplitude, but has a frequency-dependent, non-linear effect on the phase of each frequency. The result is a signal whose overall spectrum is shifted by various amounts at each frequency. For example, the phase of a frequency at the low end of the spectrum may be shifted by 1/4 of a wavelength, while a frequency at the high end of the spectrum may be shifted by 3/4 of a wavelength.
bennychico11 said:Your rant is all great and wonderful....
but actually, massenburg calls it a Phase button...not a phase invert/reverse
Avalon calls their button Polarity (correctly)...and uses the term "phase shift" correctly later on in the specs.
And, you can't really dispute the scientific definition of phase....no matter which "legendary" engineer/manufacturer said it.
Phase: the time position (or angle in the complex plane) within a cycle of a periodic waveform
To reverse phase would be the same as reversing time.
Ford Van said:Every fucking engineer for the last 4 decades has called it "phase reverse", and every one of us has understood what that means.
bennychico11 said:Phase: the time position (or angle in the complex plane) within a cycle of a periodic waveform
Ford Van said:Of course it is being used correctly! That button has been referred to as the "phase reverse" button on gear since the freakin' beginning of time! All of a sudden every major player in the audio developement is WRONG because somebody wants to play with words?
NL5 said:The definition is the POSITION in Time (time position). If you reverse it (ie flip it 180) then it would be the reverse of what it was (reverse phase/ inverted phase). It is being used correctly.
A waveform, like all analog audio signals, is an alternating-current (AC) signal, which means that the signal voltage repeatedly alternates from positive to negative. The voltage starts at 0V, goes positive, then negative, then back to 0. This completes 360 degrees of the waveform, or one cycle.
For example, on many mixing consoles, each input has a switch labeled "Phase," and the user manual might say that the switch "puts the signal 180 degrees out of phase." This switch doesn't really shift the signal in time; it simply inverts the signal's polarity.
Why the "Phase" label? Well, in the early days of electronics, the term phase was used to refer to the polarity of audio signals, and the word polarity was reserved for describing power signals. Technically, this terminology isn't correct for complex signals, but the industry still uses this convention.
-Bob KatzThe polarity of a loudspeaker refers to whether the driver moves outward or inward with positive-going signal, and can be corrected by a simple wire reversal. Remember that phase means relative time; phase shift is actually a time delay. The so-called phase switches on consoles are actually polarity switches, they have no effect on the time of the signal!
pipelineaudio said:If you want to make an argument out of such a worthless thing to argue over, then you would have to specify more than just calling it a "phase" switch. You would have to say
If its up, the signal is in its "in phase" if you press it in itsd in its "out phase"
easychair said:Almost as good as the DI thread in Recording Techniques, I see.
bennychico11 said:nah, you guys don't have a "fuckin' pussy" in your thread![]()
