whjr15
Just a quick question since we're on the topic... What exactly is "phasing" when talking about mics?? I know what "speaker phasing" is, but have never heard the mic phasing issue defined.
thanks
thanks
There's another thing you can get working to help with the hollow combing sound. As you pull the second mic back farther to get more of the random room reflections, that tends to fill in or average out the holes in the response. It might not be a direct enough sound for the style you're going for, but some where in between it might work out.ericlingus said:I really would rather use two mics at the same time. Once I get the phase issues dealt with I will have no problems with it.
Yeah, always different but not necessarily better.metalhead28 said:...I've found that whenver I've tried to move waveforms to line them up, no matter what I do it doesn't really get alot better....it just gets different. I suppose you could find a magic spot where you liked the sound....who knows.
ericlingus said:Does anyone else have advice on getting an atmospheric black metal guitar tone?
ericlingus said:metalhead do you have AIM?
How many tracks do you think that riff is? Anything else you can comment on it?The point of this (if the sound of it works for you), is if you're having phase issues, try pulling the far mic back more. The room reflections can help smooth over the peaks and holes in the sound. This would be where there's a mix of direct sound from the cab and room sound.ericlingus said:I don't understand what you said really. So you're saying have one mic up front and the other farther back? That's what i'm doing. ?
Generally:Chang said:Folks: i'm reading this thread with interest, as I have recently started recording acoustic instrument-based music. Perhaps I've been lucky (beginner's luck) in not having encountered any sound problems, but how would I even know whether I was having a phase problem? Is there a distinctive sound that results as a consequence? I'd appreciate if someone could advise/describe what "symptoms" might suggest phase problems.
Thank you so much.
