bennychico11
cpl_crud said:t=d/340
what's the 340 for? just out of curiosity?
ericlingus said:see I can't figure out how to do that. I cant see both waveforms up close together. One or the other is on the screen.
bennychico11 said:sorry never noticed that someone else posted this.
phasing does result in attenuation, though. When the out of phase signals (out of time signals) are summed together certain frequencies cancel creating a comb filtering effect.That isn't the attenuation I'm talking about. You want the mics 3 times farther apart than they are from the source. It helps with phase cancelation because the two mics are not hearing the same thing.
But if you turn up the distant mic to be as loud as the close mic, you just lost the advantage.bennychico11 said:Separating by AT LEAST 3 times the mic-to-source distance creates a level difference of 9dB or more in turn reducing the comb filtering dips to an inaudible 1dB or less....
No it isn't, the neck is a different sound source. The sound doesn't come from only one spot on the guitar. The mics will be the same distance from their sources.bennychico11 said:Using the 3:1 with a guitar when micing the neck and body is the same thing as micing the cabinet with a close and far mic, in my mind. In the acoustic guitar example, the neck mic is the far mic in relation to the body. It's still a further distance away from that sound source than the close mic is.
Thanks so far though guys.Your zooming in making things tall, you need to zoom in and make things wide. It's the zoom slider in the lower right hand corner across the bottom.ericlingus said:see I can't figure out how to do that. I cant see both waveforms up close together. One or the other is on the screen.
ericlingus said:I like to mic my amp with two mics. Right now im using one sm57 and one es57(copy of the original). I like to close mic one( about 3 inches away) and another one about a foot away. I put one on axix(the closer miked one) and one off axis. But I can't get rid of the phasing. I tried changing the mics around a little but it still doesn't work. The only way to get rid of it is if I both put them the same distance from the amp. But I dont want that sound. I play black metal and prefer a little more distance on my guitars. I have a mesa boogie F50,the two mics I mentioned going into a firebox. Cubase LE is my recording software with a pretty high end computer.
It's all about the music, right?
RAMI said:I have a question about lining up the tracks. Doesn't that defeat the purpose of having one further away, especially if it's 2 of pretty much the same mic. What's the difference between going through the trouble of micing one far and one close then lining them up...or...Just placing them equal distance from the source.
That's all there is to it. I think. Is that all there is to it lingus?speed of sound in air in standard units (ms^-1)bennychico11 said:what's the 340 for? just out of curiosity?
ericlingus said:sounds different to me still doing it this way. As far as using the same mic, that'll change in a few days when I get a E609s. Right now i'm still experimenting. How is it being lazy using two mics? I still do multiple performances.
