peaking at low decibals...
  • Thread starter Thread starter thesedaze
T
thesedaze
Hello folks,
I am running an Echo Layla based setup using an external board, and Cubase SX as well as Nuendo. After making sure the levels are right on the board, when I am recording in Cubase or Nuendo, the levels (decibal wise) are soooo small. Visually it's like a midget wave form in all blue. I checked the layla mixer, and the levels seem right on visually. Is there some value I need to customize in Cubase/Nuendo or the Layla setup so that I get the right recording levels? It seems as though there's some sort of built in compressor/limiter type thing working here...
any ideas?
thanks
Your soundcard should have a mixer section you can check and make sure the level is up on the line-in channel.
