PCI firewire hub: what latency?
  • Thread starter Thread starter schnoops
schnoops
Hi,
I have an ABIT KT133 and I want to invest in a firewire audio interface for the future, and the only choice I have is to update my puter with a PCI firewire extension board, because the KT133 does not have it built in. Will I have the same latency (for instance with the forthcoming M-Audio Firewire 410+PCI firewire extension) than the one I would have if my motherboard had a native firewire interface or will the latencies be added together?
schnoops said:
Hi,
If you're using a desktop, why bother with with Firewire anyways?
PCI is still faster than both USB and Firewire and PCI devices cost less.
I would be more inclined in replacing your system as the KT133 chipset is notorious as far as issues with DAW hardware and software are concerned.
Ive noticed my performance increase with the Firewire upgrade from PCI. Either the drivers are just better or the firewire added some speed..........
Re: ^^^
PCI - 100 Mbytes/sec and higher
Firewire - 50 Mbytes/sec top bandwidth
I hate to burst your bubble, but it just isn't possible for Firewire to be faster.
The firewire interfaces claims a 400MB/s theoretical bandwidth, and the mLAN protocol based upon 1394 claims a 100 16/44 tracks +256 midi channels+ synchro and control data on the same wire with no latency, so it's actually better than everything that existed before.
And was looking at firewire because I might have to move around frequently, so I want to be able to take the interface with me and plug it wherever I end up settling down, I also plan to get a good laptop and travel a bit, I thought firewire was the most versatile option.
By the way, is there anything fun to do in Portsmouth Virginia?
Firewire is 400 megaBITS per second, not bytes - PCI is 100 megaBYTES per second...
8 bits = 1 byte so 400/8=50
