B
brainofj
Can anyone recommend a descent pc case with a 550w power supply, i will e using an amd athlon processor with a barton motheroard and up to 1gig of ddr memory.
brainofj said:The 550w was suggested to me as i will be adding more stuff eg: more ddr ram etc. I am getting a silent power supply, will find out when i try it, if it is silent as they say.
mpthreer said:well i dunno, but check out these power supplies, i do know you have to have a whopping system that looks like las vegas to eat up a 550 watt power supply, unless your running a server pc with a big raid/hard disk system and dual processors and all kinds of shit, but i think a 400 watt ps should do you good, check this one out==
its supposed to be silent
http://www.newegg.com/app/viewProductDesc.asp?description=17-103-213&catalog=23&manufactory=BROWSE
peace
peacebrainofj said:Here is the actual set-up i will have - AMD *Retail* Athlon XP 3200+ *400 FSB* Barton (2.20GHz) with AMD Heat Sink Fan
120Gb Maxtor Diamondmax Plus 9 (7200rpm, 8MB Cache)
512Mb PC3200 (PC400) DDR Memory (Elixir Major) Retail
Abit KV7 KT600 DDR400 400fsb x8AGP +Lan+USB2+ATA133+2xSATA+6CH Audio
I will also be using a ge-force titanium card for now. The power supply i got is a Q-Tec 550w , the power supply was quite cheap 23 british pounds. Seemingly the noise is below 33db, is this quiet enough?? I will find out soon as it will be built by the weekend.
I have a P4 running at 3.6GHz with 1 GB of DRAM, four SATA hard drives, a DVD burner, a CD burner, and a 3DLabs Wildcat 760 CAD-level graphics card in a case that has five fans of its own. I also have a monitor on the input power to the (480W) power supply.Sangram said:550 watts in a high-power PC is really not really overkill, leaves a lot of room for future upgrades.
TripleJ said:ditch the 'qtech' and get an antec. Or Zalman. Or Aopen
rfarris said:I have a P4 running at 3.6GHz with 1 GB of DRAM, four SATA hard drives, a DVD burner, a CD burner, and a 3DLabs Wildcat 760 CAD-level graphics card in a case that has five fans of its own. I also have a monitor on the input power to the (480W) power supply.
Under normal conditions (like now) my PC draws about 130W, under intensive load it draws about 150W, and at startup (when maximum current draw occurs) it draws about 220W.
I second the nomination for a Lian Li case, with Antec a close second.
