miroslav
Cosmic Cowboy
No one is going to die from a balanced power UNIT!
Exactly.
K. But in the real world, we create redundant connections between the chassis grounds of our devices all the time, and there are a number of reasons that this might cause noise - at least some of which don't really have anything to do with how "clean" your power is.
Yes, true...but I think one of the side-benefits of going with the balanced power unit, at least in my own setup, is the fact that everything comes back to the singular power distribution point, which creates the basic "star" grounding scheme by default.
Now that isn't necessarily 100% foolproof...there's a lot to do with how each devices deals with chassis ground, signal ground and earth ground...but like most studio solutions, be it power or acoustics, etc...it's a series of steps that are often needed, though at this point, that way I've staged the power distribution and with the addition of the balanced power...the hum/noise/loops issues are their most minimal ever.
Before that...I've been down the other roads too in the past.
Running individual ground lines from devices back to a single point...running a main ground line out of the building to a buried copper spike. Even having to jump chassis grounds between a couple of units in order to kill the hum of one.
I've isolated the patchbays from the rack rails with electrical tape and nylon washers, then run ground lines from the bays. Even isolated each piece of audio gear from the rack rails and their chassis from the other racked gear....
...I mean some serious exorcism shit...
TBH, I think the first good step in this studio was the running of dedicated power from the main house box, on it's own set of 20A breakers, on the same leg. Back in the past, I was fighting "this old house" electrical weirdness from the git-go.
So...I think if you deal with it from the start, at every step...it will minimize and even eliminate any issues at the bays.
Of course, the whole splitting the signal thing can change that.
I've got for sets of "mult" groups on one of my bays, each with 4 splits, which lets me take any piece of gear and split it to anything else if needed...as opposed to "pre-splitting" a piece of gear permanently on a bay.
That way it minimizes the potential, but still leaves room for plenty of options when needed....and then if some noise pops up, you deal with it.
