D
dintymoore
Guest
I put this box together. I'm hesitant to call it a passive preamp because it doesn't preamp anything. It goes right before my studio speaker amplifier and does this:
* has stereo inputs from my mixer to hear the audio and MIDI tracks and another pair from the soundcards L/R outs for the final mix. That allows me to monitor recording then listen to playback without switching anything. The final stereo tracks go straight to the amp and don't go through the mixer. I fought with that problem for years.
* has two toggles on the front - one turns the sunwoofer off and on and the other kills everything.
* has L/R sends to my speaker amp, a headphone amp and a subwwoofer system. I haven't used the headphone outs.
* large detented Noble 100KΩ volume pot which is numbered and makes it simple to return to the same playback volume. It was scavenged from a 70's Mitsubishi receiver/small boat anchor.
The enclosure started life as a Digitrex 12 bit effects unit, probably the worst of all time, it has 1988 stamped inside of it. You can see I added flat aluminum to the front and back to cover up the old holes. There's a metal cover that goes on top.
I used 10KΩ summing resistors on the inputs.
The one numbered "9 + 10" is the final L/R mix, the one labeled "MAIN" is from my mixer:
This is a working mock up. I'm not... er... too happy with the aesthetics. I hope to rebuild it sometime and maybe combine it with an ugly working mock up speaker selector I made. I would use a wood cabinet next time.
But technically, this box solved a lot of problems that drove me nuts before... like switching to hear playback vs monitoring recording and also the basic question "how loud is it?".
