Scrap it and pick up a couple of G.Skill Ripjaws
The last I heard, there was still an issue with the longevity of the SSDs, it can only do so many reads and writes before it craps out, and this is much less than the magnetic types. This, to me, seems like a very bad thing for a DAW, since damn near everything we do is either reading or writing to the disk. Was a couple years ago that I really looked at it though...
OTOH, if you grab the freeware program called RAMDisk, you can allocate a portion of your RAM and make it look like an HD to your OS, even if it wouldn't normally be able to access it as RAM. My recording machine runs 32 bit XP, and I have 8Gb RAM. The 5Gb that Windows can't use is a tiny little hard drive that I use for my virtual memory. So, the page file is just as fast as the RAM that it's "emulating". Works pretty damn slick.
I use both MAC and WINDOWS operating systems
I have to say, I sometimes find problems with windows, and if you have never used MAC, I recommand you buy a MAC or at least use the operating system and check and see how much faster and easier it is to use MAC,
I use Live 9 and Komplete 9 Ultimate Library, my MAC runs it almost 2 times faster although my PC is more powerful, only because WINDOWS SUCKS...
Apple is expensive for its parts, but imagine if you build a PC with installing MAC operating System OSX lions on it... that would be a great saving![]()
If I am not mistaken, that would be illegal. Apple doesn't work that way, Microsoft does, but not Apple.I use both MAC and WINDOWS operating systems
There's a damn good reason for that, in my opinion.
If apple allowed the reverse of bootcamp they'd be immediately inundated with complaints and issues.
The reason for the greater majority of issues on windows platforms is the massive availability of hardware.
$5 FW card doesn't work right and all of a sudden windows sucks?!
I mean, I don't like windows, but it gets a bad rep for the wrong reasons.
Mac stay to their extremely limited (and expensive) range, and for that reason a lot less is likely to go wrong.
A carefully planned PC build and educated setup can give you just as stable and capable a system as any mac, but not everyone knows how to do that.
Apple usually just cuts bait and runs to the next generation. Meaning, go by new stuff. MS. for what ever reason, keeps legacy hardware/software running. I have some software (haven't tried it with Win7) dating back to the early 90's I could still run and I can still read my files from the 80's.
But, to be balanced, Apple took a different approach (system approach) and suffered for it through out the 90's and early 2000's
Didn't see anywhere to post this particular question, but I'm looking at off the shelf PCs, and wondered if this was a good starting point, HP Envy 700-214, 4core i5 4440, 12GB DDR3-1600 2TB 7200 RPM SATA HDD, 3GHZ 3. SOMETHING IN TURBO, A gazillion usb 2.0, and 3.0 ports, tons of pci slots, and more card readers than I knew existed. I'd need to wipe the crap, and it is win8.1, and it has three monitor outputs. All for $749.00, with keyboard, and mouse, which are wireless, so I guess they won't get used. So, good starting point for a Tascam DP-24 owner planning to edit, and use VIs in Reaper?
Please, I know you're out there Obi-Wan Kenobi, you're my only hope!!!
