D
DM60
Not even sure if this thread is even worth while, but thought since most of us pretty much do thing alone, might be a good place for tips and tricks.
One item I did want to bring up was, a controller on a tablet or phone for remote control of the recording computer/DAW. I know Reaper now has the ability to control their software via web app. I assume they are using Nose.JS since it doesn't require a webserver to run.
I started using TouchDAW a couple of years ago, but at first it really didn't work well. Then they just updated some drivers for Bonjour and the app itself and now it works really well. Plus it sets up like a controller. So it is probably supported by most DAWs that interface with various controllers.
TouchDAW - DAW controller and MIDI utilities for Android™ Works on Apple and Windows for DAW, works on Android OS and IOS.
Nice thing about it is, if you are doing any kind of mic work and you want to stay away from the computer, set this up, run your mic as far as you can, have your tablet or phone near you and you can get your takes in without going back and forth. I found acoustic work or vocals it is a pain to record by yourself because of the back and forth. Plus setting up the mics for sound and testing.
I am sure there are other uses, but mic setup and recording I know it is very useful.
That's my first tip.
