K
kats
I'm testing some SD mics against an el cheapo Apex SD to help me decide which way to go on my upgrade.
Using the exact same mic technique on an acoustic (one bridge one neck in stereo about 1 ft away) the c4 came off real dead sounding in comparison. None of that crystal clean high's you get off of an acoustic. Now I think I've screwed up somewhere, because considering the reviews of this mic this should not be the case. (direct into digi002 pre FYI)
So dumb question number one. I assume the cap with the holes around the side is the omni capsule and the other one would be the cardoid. I assumed I was using cardoid when I recorded with the C4.
Dumb question #2 Is it common to have to make drastic mic posistioning changes on mid to high end mics if your used to setting up el cheapos? And is this my problem?
