WATYF
...happier than you.
Alright.. so after having a horrible time with the initial set-up of n-Track... I have finally found a configuration that works relatively stable. I discovered that certain variables (like which 24 bit setting I used) were causing stability problems.
So now that I can record without incessant crashes, I need to take care of one of the other problems I'm having...
I can't hear the metronome. This is what happens. I have to change the Windows settings so that all sound is played through the Delta 44. That way, when my generic midi plays the metronome, I can hear the sound through my headphones (which are plugged in to the Delta 44) So I hit record and the metronome starts, and I record a take.. and then I go back to do a second track and hit record, and there's no metronome.. I can hear the first track I previously recorded, but not the metronome. As soon as the first track finishes playing, then I can hear the metronome again, (which makes it worthless, because I don't need it when the song is over,.. I need it during the song)
So what's the deal...? It's as if the wavs and the metronome can't share the same "space" and that it's either one or the other... so how do I get around this? Any ideas?
WATYF
WATYF
