Old Music Guy
I just bought a Harley Benton Thinline Nashville Nylon guitar.
The tuning machines are 18:1 typical open back. All but one of the strings (the D string) are original to the guitar. I had to replace the D. I replaced it with a D'Addario Pro-Arte. normal tension, .029" (0.74mm).
My question is: The guitar does not stay in tune after is sits for a few days. It's on a stand in my living room, temp is ~ 71F (21C). I play it at least every other day, but I need to tune it every time I pick it up. They are always flat by 10 or 20 cents. This includes the new D string.
The machines are very tight. Gold plated. Asian.
Not knowing what the tension is on the original strings, should I have replaced the whole set?
Or, can it be a tuning machine problem?
I'm not losing any sleep over this, but I would like to know if anyone else has ever experienced a similar problem?
I should add that none of my electrics, that reside in the same environment, exhibit this problem to this extent.
EDIT: Forgot to add that the guitar goes flat WHILE I'm playing it. DUH!
