not so HOT RAILS....help wiring
  • Thread starter Thread starter lesterpaul
Status
Not open for further replies.
lesterpaul
lesterpaul
hi just bought and installed a hot rails pickup.also purchased a push pull pot so i can split th coils i'm enclosing a pic i hope you can make out .the stock fender pot had 3 solder points near top and 3 points on bottom....push pull had 3 at top and 6 on bottom 3 per side
the hot rails had 5 wires green/red/white/black/uncoated gray
I wired it this way .....green and uncoated wire together and to middle post on right side
white to top"as you look at pic"
red and all other hot wires to individual posts on left side
black wire to switch
with switch in down position i get a little sound but total crap up gives nothing ....yes it's probably easy to see but i need help ....thanks in advance
Status
