non powered or powered mixer?
  • Thread starter Thread starter Wack
W
Wack
Hey guys, question about a mixer board. I'm currently using a Tascam dp-02 portastudio. I'm wanting to use an external mixer ( I don't use a computer so I figured a mixer over interface). I'm wanting something with 4-8 inputs being guitar and mic. The reason is is live recording, and drum micing. The 2 inputs on the Tascam are just not cutting it (though this portastudio is fantastic in every other way). My question is do I need a non powered, or powered mixer? I was told powered was for live PA mixing. And non powered was for powering boards and recording via tape deck etc... Is this true? Thanks!:drunk:
Either will work (for recording or PA). However, unless you are doing live PA stuff, you don't really need a powered mixer.
Would it make sence to get the powered mixer just in case I do end up doing some live PA stuff. Is their much of a price difference?
Would you still be using powered monitors?
If you are unlikely to be doing live gigs, I'd suggest opting for the mixer.
You can always rent or buy powered speakers for a live gig.
I'm just looking at what would have the least impact on your current set up and I think that a mixer would be a simple addition.
I'm a real sticker for keeping my live and studio gear, separate, by the way.
That way, the studio gear stays unblemished and my gig case is always fully stocked.
For that reason, I have a mixer and a powered mixer, studio monitors and PA speakers plus a dozen or so studio microphones & two others which are strictly for live performances.
There is absolutely no difference in quality, just my way of keeping the gear straight.
Yes I will eventually be running through powered monitars. For now I run through headphones or a guitar/bass guitar amp for mixdown and mastering. So If I just want more channels, and a little more power behind the tracks, It does not matter if its powered or non powered? Thanks for all advice!:)
Now hold on just a minute here!
You NEVER want to run powered/amplified speaker outputs into a recording machine. The high voltage will burn it up. I hope you realize this much.
My God, Wack, I hardly know where to start. Here's a snippet I wrote to a guy who was asking about PA's:
"Every PA is a combination of a mixer (which is a bunch of preamps with controls that sends however many inputs you have to a smaller number of line outs. It usually has EQ on each channel, and adjustable reverb for each channel), a power amp (which raises the line level to something that can drive a speaker), and one or more speakers (usually in at least 2 identical arrays). Each speaker array is likely to contain dedicated speakers for lower frequencies (woofers), higher frequencies (tweeters/horns), and midrange frequencies (drivers). In larger systems, a single subwoofer is added to handle really low frequencies.
The differences are in quality/price (like everything else in the world), power, number of channels, and what boxes the components are in. A component system keeps it all separate. You use an unpowered mixer (most basic mixers are unpowered), to one or more separate power amps, to passive speakers (ones that don't have a built in power amp).
Another version is an unpowered mixer to powered speakers, such as Eons. This is very portable and simple. The downside is you can't use those power amps to drive anything but those powered speakers. The upside is it's simple, and usually, the amps are well matched to the speakers, because they were built to work together.
The third version uses a PA head or powered mixer to drive unpowered (passive) speakers, It's the same deal, but the power amp is built into the mixer instead of into the speakers.
No matter which version you use, the mixer, the power amp, and the speakers have to match in impedence and in power output/input.
So which is better? No simple answer, dude. It depends on your preferences and your needs. One thing to remember- The more components you have in one box, the more convenient and portable it is, the less versatile and flexible it is, and the more stuff that's out of action if one part of it breaks."
For your purposes, a powered mixer makes no sense. Some really good powered mixers have line outs, but on many, there are only main outs for driving speakers. You can't use those outputs into a digital recorder. The signal that drives a speaker is not line level, and you don't ever want to plug a speaker out into a line in. That, as Moresound says, is very bad juju.
Be advised- the purpose of a mixer is just that- to "mix" a number of inputs into a smaller number of outputs, with multiple routing options. You are trying to get more inputs, but only a few mixers will give you separate line outs on each channel. The groups of outputs are called "buses", so a 16X4 mixer has 16 inputs, and only 4 outputs. If something is mixed together on input, you can't separate it later. So- The first thing to do is find out how many tracks your recorder can simultaneously record. You can't change that. In your case, I think that's 8.
So what you really need is not a mixer. What you need is at least 6 channels of mic preamp s with 6 lines out. For cheap (as they go), consider Behringer ADA8000:
http://www.8thstreet.com/product.asp?ProductCode=20720&Category=Audio_Interfaces
So here's what you do. First, get a short optical toslink cable (1 foot will do). Connect the ADAT out to the ADAT in on the 8000. Now you have an 8 channel mic preamp. Then you need a bunch of XLR to TRS 1/4" cables (whether you use a preamp, a mixer, or whatever, you're going to need a bunch of cables for all those inputs) and plug those line outs into the line ins on your channels 3-8. All I can tell you is that the preamps on the Behringer are at least as good as the preamps on most mixers,and in many cases better. Now you have your 8 channels in. Best of luck.-Richie
Good post, Richard.
I have the Behringer 1204 FX for studio and the Behringer PMP 1280 S for live gear. Absolutely no difference in quality and plenty of "Line Outs" in both units.
I also have the Behringer ADA 8000 and wholeheartedly agree with you on it's usefulness.
In fact, I'm keeping my eye open for a PCI card with ADAT I/O with a view to bypassing my current interface completely.
Strikes me as a quiet, efficient route to go.
Well of course he does.
That's why we were discussing powered versus passive monitors.
At least... I presume he does. :laughings:
...and plug those line outs into the line ins on your channels 3-8.
I don't think he has any channels 3 to 8 on that Tascam. Doesn't it only have two inputs? It was a good thought, tho.
Wack, to answer your original question, a non-powered mixer will work fine for recording. As long as you understand that the channels from the mixer will be permanently mixed (to at least two channels) before going to the Tascam.
But then again, for not much more than the cost of a new mixer, you could damn near upgrade to a larger portable recorder with more in's. And then keep those extra channels separate for mixdown.
But then again, for not much more than the cost of a new mixer, you could damn near upgrade to a larger portable recorder with more in's. And then keep those extra channels separate.
3 Minutes Ago 09:57
Sooooo true!
My mixer is strictly for monitoring with effects while recording.
There are plenty of used recorders out there.
Oh my God, you are right. Only 2 channels in, but 8 out. My bad. You can feed those (2) line ins with a mixer, but what you'll get is a stereo recording of a final mix. Once it goes in, it is what it is. So you could send a drum mix to 2 channels, and you could adjust the relative volumes of left and right. It seems to me that if you can't live with 2 channels in, you'd be better off upgrading your recorder to something that can record more than 2 simultaneous inputs. I see a mixer as being a half-assed solution that may cause more problems than it fixes. Consider something like Zoom R16:
http://www.8thstreet.com/product.asp?ProductCode=60335&Category=Recorders
This is why I come here, you guys seem to know it all:D. Thanks for informing me about the amp to headphone jack. I am still in need of monitors so ill stick with the phones from now on. The main things I'm wanting to do with a mixer/preamp is record drums(4 mics), live acoustic recording (3 acoustic guitars ran at once), and 2 acoustic 2 mic lines... I'm guessing I could do all the mic lines over a preamp and the instrumental recordings DI to the tascam. Why I was wanting a Mixer was because of the power It gave my tascam when I used them together at a buddys. My OL levels didn't have to be nearly as high. With the tascam alone, After a master all levels turned up to appropriate levels, Tried in 2 different car stereos the volume level had the be through the roof to even hear it. My master fader was up through all masterings. I just wanna bump my shit yo.
Also, With the tascam do I want powered or non powered monitors? non powered I assume?:o
Wack: What you have right now, is the wrong tool for the job.
You don't have enough inputs to record a band and you're looking at spend more money to make it work.
The gear that Richard just told you about was built just for you.
Check out the Zoom R16.
And yes. Powered monitors with that one.
I checked out the Zoom R16. It looks much more ideal. Wish I would have seen that a month ago :(.
