H
Harpkonst
I've been struggling with noise problems ever since I started recording my stringed harp. Finally I got a little money so I'm thinking about upgrading my gear, but I don't now where to start.
The signal path I'm having now:
Harp - dynamic mic less than 20 cm away (Shure sm58 and/or JTS TK600) - xlr-xlr-cable - Steinberg CI1 soundcard (gain close to max) - usb to computer (at the moment Sony Vaio, but I've had the same problems with earlier laptops and stationary computers)
Somewhere down the line there's a noise picked up and recorded, I think it's to loud but maybe it's a normal noise that I have to live with. What do you think? (here's a clip, raw, the noise is best heard in the beginning before I start playing. (There's a metallic ringing noise when I play too, but that's some part of the harp vibrating, I will try and localize that and muffle it somehow later)).
https://onedrive.live.com/redir?res...2304&authkey=!ACcRhlSYuM7ztn0&ithint=file,wav
The noise is all over the spectrum, so it's hard (impossible?) to remove with EQ. Noise reductions (like Reaper's fir) makes the harp tone sound too bad I think. Noise gate don't use to work well with the harps long tones.
I don't think it's the noise in the room that's picked up. I don't hear any difference from when the room is very silent to when the refridgerator starts buzzing and the computer fan goes on. I also tried to move the harp and mic into the small walk-in-closet (very quiet place) but the noise recorded was still the same. I'm very carefull so the soundcables do not get close to any powercables.
I have tested with both the mics, different cables, another usb-cable, different distance with the mic from the harps soundboard - still the same noise. Ok, I don't have very expensive gear, and I am recording in my livingroom, but if I should upgrade something, what should I start with? Or is there anything else I could try?
It would be so fun to be able to make nice recordings, I've been struggling with this annoying noise for years.
Any tips?
Any tips?
