M
moresound
Loud Sun Studios
Interesting.
So your looking at the same upgrade that can be applied to the 460 as well?
It's good that you want to promote your friend's mic but seriously.
Don't knock the gear if you have no experience with it.
It's a damn good mic.
I have an AKG Solid Tube on the way.
Will that do?
12AX7's gain is too hot for mics and pushes into distortion too quickly, which is why 12AY7 or 12AV7 is better.
Yeah, that's definitely the Aurycle kit mic. I bought two or three of them. They are the same mic that was sold as the sE5000 (IIRC) and another famed mic (with a different capsule).
I tried modifying the board, but ended up just copying the Ela M 251 circuit (adjusting for remote pattern control) with a Tim Cambell capsule and a Lundahl transformer. I also found a better grill off another mic that matches the Ela M's grill mesh count.
You know I have no idea what that means. "You may not" something?but of course, YMMV...
Indubitably.A 6mm can't do what a 16mm or 34mm does, and vice versa.
Nobody complains about the KSM32 much, that is a 16mm capsule. So are a lot of pencil-style mics that are well regarded.
Kidvybes: I enjoy your posts. I usually find you very informative.
However, publicly dismissing microphones without trying them is all too commonplace on these forums and quite frankly, something that I had presumed you to be above.
I have the T-1. It rocks. I can say that because I've tried it.
Anyway, the real point is, I enjoy your opinions. Usually.
....... and I'm off to Alloy Music to see what they have.Interchangeable tubes (in alphabetical/numerical order):
5751
6072
6201
12AT7
12AU7/ECC82
12AY7
Some good manufacturers include GE, Mullard, Philips, RCA, Sovtek.... Also, don't overlook the "JAN" parts. These are military parts, usually made either by Phillips or GE.
...so are we to believe, from your statement, that the Behringer T1 and the KSM32, having the same size capsule, might share sonic similarities?...probably not...
Put enough qualifiers in a sentence and anything is true. Might they? They might. Do they? I don't know, and apparently you don't either.
Well given that I have an AKG Solid Tube on the way, I don't see me needing the Behringer.at least until somebody buys it on eBay, seeing that he recently listed it for sale
Other than your friend's mic on E-Bay, what tube mic do you like?
Return to Sender ♫OK Jim I give up what are the acronyms YMCA and HBO stand for in your book?
