No external drive error message
  • Thread starter Thread starter starofsong
starofsong
I have connected the external roland CD burner to the VS 1880 but it is not recognizing that I have one. I have tried changing the scsi channel, etc. I have turned on the CD drive before turning on the VS 1880. I am pulling my hair out trying to make it work... someone please help me! and Thank You So Much!
Which CD do you have? The older ones have a terminator that needs to be pluged in to one of the 50 pin connections on the back of the CD burner.
The newer ones have a switch that needs to be set to terminate. It most likely has the letters T, O, and A. T=terminate O=open A=auto.
Is this the only dirve connected to your VS?
The only drive that needs to be terminated is the last dirve in the SCSI chain.
Hope this helps..
If nothing that Goforit says works, I would try to a different SCSI cable.
