newbie question
  • Thread starter Thread starter msgrape
msgrape
msgrape
I posted this on the newbie forum because I am sooooooo new but I thought maybe I should have posted it here.
Thanks.
am i doing this all wrong?
Now I have another question re. Acid.
I recently read where someone spoke of downloading all the loops from loop CDs onto their computer before using them.
Is this necessary or can you just use the loops from the CD?
Is there a difference in the music......one way being better than the other?
Once again I thank you in advance.
Some day I'll get this right......lol
msgrape
If you have the HD space to spare then copy the whole CD to your HD.
However..... I wouldn't.
Find the sample/s that you want to use. Copy ONLY the/those samples that you want to use to your HD.
spin
BTW................................
Welcome to our home here HR.COM
Thanks for the info and the welcome.
I appreciate it.
msgrape
The big issue with using loops straight off the CD is simply that it's a pain if your song is going to use loops from more than one CD. Once you take the first CD out, then the first loops you used can't be found by the pointers in the ACID file.
One solution is to save your file as an ACD-ZIP file, which saves a copy of each audio loop along with the regular ACID file parameters.
AlChuck said:
......One solution is to save your file as an ACD-ZIP file, which saves a copy of each audio loop along with the regular ACID file parameters.
That's what I was trying to share with msgrape, but you worded it much better.... ;)
spin
B
Replies
11
Views
707
BaronEstelle
B
Replies
0
Views
1K
Sunhouse
T
Replies
25
Views
5K
timhall11
T
