Herm
It sounds like things may getting better. I was wondering do you have dbx on this machine?
Ok it seems like I am on the right track. I opened up the manual again because I had not looked at it since I got the recorder and things are making more sense now. I adjusted input monitor level so it matches the input pot for all channels and I'm working on erase bias right now. (which fixed an erase problem I had with channel 2
) But I stopped at channels 7 and 8 because I cannot get them to playback at the matching level that it was recorded, even when I adjust the playback levels to the Max level. I think I need to adjust the record bias, or record EQ to solve that one? I've heard that RMGI SM911 is similar enough to the Ampex 456 in specs that I wont need to do any adjustments for the RMGI. The only test recording I have done is 1khz test tones for testing record/play back levels and the erase bias. So I dont know how the RMGI really sounds yet.
But the electronic calibration that I am doing now is fixing a lot of the problems I had when I was messing around with the Ampex. Cleaning and de-gaussing made the most immediate and noticable difference though!
), I am fine getting everything ready util the adjustment. I'm not really sure what I am watching for. The part about the VU meter rising isnt very specific. If i move the VU adjustment pot in one direction it makes the VU meter rise up until it is clipping like mad, and the other direction makes it decrease in volume. Could somebody clear this up for me? and are the "Volume Units" the same as dB? or will I have to somehow measure the dB reduction? After bias is just record level (which i will have to do again after doing the bias i guess) and the record EQ adjust.
1) Set an oscillator to a medium frequency, like 1000 Hz at a nominal recording level and monitor the recorded signal with a VU meter.
2) Reduce the bias level until the signal drops precipitously, then increase it until the meter just peaks. If you overshoot, back it down a little bit until you are just below the peak level.
3) Set the oscillator to a low frequency, say 30 Hz and monitor the recorded signal with headphones. You will hear the low frequency tone modulating the noise and distortion components. Try to separate these in your attentions.
4) while listening to the tone being recorded, adjust the bias until the modulating noise is at a minimum.
The test tape is used to make sure heads are in alignment and the levels are set right for playback?
