new to analog
  • Thread starter Thread starter superstupid
superstupid
Hi, I'm interested in going analog. We just recorded to Pro Tools, and it just didn't work out.
We've decided that for our next recording session, we want a good setup in our basement. As much analog as we can do.
We're into that "dirty" sound that you hear on Pearl Jam albums, etc.
We could probably pull it off on 8 tracks, 16 would be better, but possibly out of the price range. 16 would allow us to double tracks, however 8 would force us to really get it right (which we would have time to do since we aren't paying someone by the hour)
We would like to mix it ourselves, but be able to send it out to get professionally mastered. What mix format is the best way to go about that?
Another option we have been considering is recording the rhythm tracks to analog, and doing the leads and vocals into analog pre's into digital, where we could add effects cheaper and easier.
Also, what are good mic pre's for vocals on analog?
I would say we could get EVERYTHING onto 8 tracks, however, having 10-12 would be helpful.
All of us are ready to take the analog plunge, though.
Edit: Not entirely new to analog. I would say that one hint we had was that our practice tapes done on a tascam 424 sounded more like we wanted it to than our Pro Tools sessions. However, the Pro Tools unquestionalbly sounded more professional and finished so we went with it.
Ok, for 8 tracks:
If you can get a lower use TASCAM 388 in great shape then I'd try that. (It's a self contained mixer + open reel "portastudio"). Look here:
http://www.nowhereradio.com/artists/album.php?aid=1609&alid=-1
There are several songs recorded on the TASCAM 388. Listen to them. Remember that no compression nor any effects were used at all.
Failing the above or in addition I'd get the TASCAM 38, TASCAM TSR-8 or the TEAC 80-8 with a matching mixer such as the TASCAM m-30, m-35, m-50, m-512, m-520 or any of the m-300 series mixers.
***MUST BE IN GOOD, WELL MAINTAINED, NOT ABUSED CONDITION***
(Local purchases are always better but if shipped, make CERTAIN that proper packing rules are followed).
Stick to TASCAM/TEAC when looking for your Analog gear. Parts and full support are there still when needed.
External mic pres are not needed. The above gear is more than capable of high quality mic amping!
Suggestion: stick to 1/4" - 1/2" tape. Above that and you'll run into serious expense.
"Mix format": I think if you can score a TASCAM 22-2 or 32-2 and mix down at 15ips then you'll be alright. You can then take the 1/4" tape to a mastering house.
Good luck!
Daniel :)
A Tascam MSR-16 would be worth considering. An economical 1/2" format, and an easy recorder to use. I have seen some on eBay at quite good pricing - unfortunately all in the US. They were NZ$11,500 dealer price new in '92 (that would translated to around US$5,250 in '92, or around $8,200 now, but the US price may well have been different). I seem to remember ARP saying they were going for around US$800-$1,000.
If you can do it in 8 tracks then there are a heap of options there - from the Tascam 388 that Daniel recommended to the TSR-8 1/2".
I'm guessing either 1/4" two track or digital - possibly DAT.
The analogue purists won't like me, but this doesn't sound like the silliest thing in the world. You could also record analogue and then transfer to digital - 24/96 - for mixing. Just transfer all of your analogue tracks to digital in one pass, saves trying to synch them later on.
Cya
Andrew
I think that's perfectly acceptable. :)
~Daniel
Cya
Andrew
I have an M-Audio Audiophile 2496 and n-track with which I could do that. I would have to say that for convenience, digital cannot be beat. That was the best thing for my songwriting (and for fixing the protools recording that the hack that recorded us gave us), the convenience, and the ability to record more than 4 tracks, etc. I fully intend to use this setup for putting a mix to a CD to listen to in a car stereo, etc, experiment with effects, EQ, etc; so that I know what needs to be fixed on the analog end.
I was looking into a Mackie 16 channel mixer for this studio setup, and getting one or two good preamps and some NS-10's. We are planning on getting this to sound reasonably professional. We can afford to spend some money on a semi-professional setup, as long as we aren't paying by the hour in a studio that requires us to take a week off to record because it is out of town.
There isn't a whole lot in the way of analog in Indianapolis, but there are plenty of pro-tools hacks.
