seeking
Member
H
Hello guys, I'm new here. I figured I'll go back to mixing a bit(it's been a while). So I though I'll clean the dust of the old gear and give it a try. So here it is...
I cant post links yet so just copy the link manually, Sorry.
drive.google.com/file/d/1EPktaZ8-nBl-WQywJ3KRHNC-m-AJRoPY/view?usp=sharing
Feel free to bash away
Worth mentioning that I haven't worked in the opening solo and the back vocals yet, no automation as well.
Please let me know you thought, the good the bad and the ugly!
Cheers from Prague!
Decreased the volume jump, did away with the ping pong, lowered the volume on the intro solo, lowered the low end slightly, and cleaned up some low end just a bit. I worked on the harshness in the cymbals some more. Hopefully this is a bit better. Dropbox - Love Bites MS_2.wav
I was a live sound guy who dabble a little in recording many years ago. These days I mostly repair and modify guitar amps, effects, and some pro audio gear. I have been doing some live sound again, along with some system design and tuning. I wanted to practice some mixing and remembered this site, and found this post and decided it would be a good one to do. Anyway here is my mix. I hope you enjoy it. Thanks, John Love Bites by JSROCKSU | Free Listening on SoundCloud
Hi.
I tough hey, here someone who has added something in the intro, but after a while...nææ.... It probably just a fault that the synth choir is added in the beginning ?
And I hear that u have the same problem as i; no control of the bass. Its rally pumping as is. It also sounds like theres a lot of low cut on the drums, in general.
Anyway, Thanks for the effort.
Cheers
-einar-
I would guess that you probably really need to check your room. That may be the problems you're having. Smaart live it, or at least trueRTA and a decent measurement mic.
Reference this and see if it seems thin or toms seem boomy. Aja by Steely Dan in 1080p HD on Vimeo
. and if I didn't mention before I like the tune. Placed on purpose to add a little in that section. ( I felt the long into part needed more flavor) You didn't notice the synth at the end. I brought that up and delayed to fade with the rest. I thought it tied well back to the intro. I think it will be hard to get what your looking for without re-tracking the bass, and maybe using a subkick or such on the kick. Although I think some more 50-ish hz could be gotten out of what you have, but the bass only seems to have sounds that live in the sub and low, so. I think it currently commands this spot. Lending to the boomy bass, and the drums being thinner so they have a spot they can sit in. It will be very hard to get the bass to have any punch/ snap, because it does not exist in the recording. So I think you could get close to what you're looking for if you re-track the bass to sit in a different spot. I still need some treatment in my room also.. and if I didn't mention before I like the tune.
-John
So here is take 2:
drive.google.com/file/d/1etYtmNzxCwkXydwt8t-iW2iPTrcb4uMG/view?usp=sharing
This one was mixed on new monitors so it probably needs some adjustments and I will really appreciate the feed back.
I had lots of fun mixing again,
Hope its not to bad
Enjoy...
So here is take 2:
Hope its not to bad
Enjoy...
It's hard for me to mix on headphones. My set up is under construction, I've been doing these with headphones, computer speakers, and listening in the car. Hopefully this week I'll get everything finished up , and get the monitors back up.
Here is my latest effort.Dropbox - Love Bites Ozone.wav
Hi,
I've been pretty busy so i couldn't answer before.
Thankx for the feedback!
Yes, the lead vocals were totally dry before the band comes in (after were not dry at all).
The idea was: first, create a bigger impact when the band enters and second, reflect the "mismatch of feelings between the past and the present" using the dry vocals and the ear-candy of the delayed guitar.
But hey, if the client doesn't like it, we change it...
Yes, there was an issue with the f's and s's. It wasn't lack of de-essing (had a couple of instances applied) but pre-fader volume automation to compensate the several stages of compression.
Regarding the low end, i could differentiate the kick and the bass throu the entire song.
Probably you are right, i can't mix on monitors so i use earbuds. Obviously that's a problem.
I let you another take.
Hope you like it more than the first.
Dropbox: Dropbox - loveBitesV3.wav
Hey Einar.
I made a 1 reference you can hear if u want and still seeking a mixer ?
Greetings Oelting Beats
Hi.
Its a very good mix. Om my home stereo (who is super critical to bad low ends mix) ist just fine. Well balanced.(but that could also mean to low on other system, lol ..its a never ending battle) I also have to apologies to everybody as i realize that my solo intro guitar track has been bounced all clean. In my mix Iv used Bias Amp 2 on it.
I dont know exactly what it is with the main voice, but it sounds like there are a bit to much compression or gate..?
Iv also done some re-mixing of my own on the song, and there i adjust the volume on the synths a bit lower here and there.
all inn all, a good mix.
Thanks
-einar-
