J
jasgav
I’m replacing the stock Ibanez pick ups in my 7 string with Dimarzio blades. The guitar also has a 3 way switch. I wired the neck pup in a series and the bridge in parallel. When I put the strings back on and with the switch in the center position the guitar sounds great no hum, clean, way better than the Ibanez stock pups. Move the switch in the neck only position and nothing but hum, same when you move the switch into the bridge only position nothing but hum. When I was removing the stock pup it looked like they had the first two prongs bridged and last two prongs bridged so I did it when I put the blades in. I can’t remember what I was thinking when I wired one series wiring and the other in parallel (does this even have anything to do with the problem?)
What do I try next?
What do I try next?
