E
evadbowl
Member
Does it matter what kind of sound card that you get with a new PC if you are going to use a Audio Interface? Thanks.
i dont use a sound card...i use a mackie micro mixer that plugs into my line in HD jack with a certain cable...it works the same and has more channels..
If you use and Audio Interface it will replace the computer's internal sound card when you are recording/playing back rom your DAW software if you configure everything correctly
the soundcards built into modern computers arent all that great, but I wouldnt call them bad either..the computer's sound card and it is handling the Analog to Digital conversion (probably quite badly)
Which, btw, is infinitely preferable to using a stock sound card or "soundblaster" type sound card.
Thought that should be fixed... There are plenty of very good aftermarket recording-specific soundcards on the market. But, none of them will come stock in an off-the-shelf computer...![]()
Totally agree. . . That's basically what I meant - the default soundcards in pc's these days don't really lend themselves to good quality recordings. (As if they ever did?)
ok so im about to buy some studio foam. Theres no way in hell im buying at guiar center for 200 a panel. ive been looking at egg crate foam and other stuff. Any suggestions??
THANK U!!! its perfect......but will it make a difference?
