New owner of Neotek Series III. You guys weren't exaggerating about the level of commitment.
A
AnalogApples
Member
I thought I'd update you guys on a recent development at my private studio. I just got back to Madison WI from Nashville with a 24 channel Neotek Series III console that's been converted into a side car. He basically sold it to me for a song. It's totally wired up to a punchblock and patchbay, with cables coming from the punchblock that go to all my gear. My first observation, this thing is enormous. Everything is double the size of my Tascam M3500. Looking at it is messing with my mind because photos make it look like a modern, compact console, but in person it's huge. One fader panel barely fits in my hand. The knobs are huge, the pots feel totally different, like I imagine big gears underneath turning as I rotate the knob. So strange! The appearance just screams "REAL professional console'
My second observation is that the wiring is humbling. It must've taken a team of technicians an entire week to run wires from the channels to the punchblock-to the patchbay. Hundreds of pounds of copper bundled in rubber so thick it looks like fire hoses coming from the console. I can see how the cables cost $thousands to purchase, and additional thousands to connect.
Also, patch bays are a new frontier of mystery for me. Normalled, half normalled? Good grief. I have many questions, and since large format consoles are not as common as my Tascam, educational material is limited.
Right now it's set up so that you use 2 of the 24 busses as a master 2 mix. There are no master channel cards. The only card that isn't an input module is a reverb return module, which i'm guessing outputs it's signal to the patchbay--but how that ends up back into my 2-mix--i'm going cross-eyed.
Right now I'll be using it to preamp and EQ my mics before my tape machine, a Tascam MS16. It's a +4 console, so I think I can use the XLR ins/outs of the tape machine. There's a switch in the tape machine that changes the operating volume so I have to check if that needs to be switched. Then I'll run the tape machine back through the console to mix, out to busses, and into my Tascam M3500 so I still have master channels and VUs of my 2-mix signal.
Long term, I'm on the hunt to buy all the channels that would make it a factory complete Series III. I THINK I just have to wire the master channels into the patch bay, and I'll be good to go. I'll be adding on to its wooden frame to create a spot for the meter bridge, and for all the remaining master channels. The console wiring appears simple enough. I'm really hoping the master channel PCBs have labeled solder points for wires.
I am so excited to get this into factory shape so I can sell or donate my Tascam M3500 32 channel. There's too many huge consoles in my house right now.
Has anyone tried restoring the master sections of a sidecar console? Was it a wiring nightmare, or pretty straightforward Inputs and outputs, power etc?
Interesting: He says he paid $10,000 for the console, and another $7,000 to wire it up back in the late 80s. I paid him 12% of that amount, so you do the math. Like I said, a song.
2nd photo is the rear of the console, so you can see it looks deceptively simply wired. I'm hoping the master cards have similar simple wire ins/outs.
It looks like all that wiring on the rear is 'wire-wrap'. You'll need tools.
It does look old.
He gave me all the wiring tools in the sale, fortunately. And yeah, it's almost as old as me! I haven't powered it on yet so the suspense is intense.
I’m happy that people like take on jobs like this - for 2000 bucks it is still a lot of work - and where do you put it?
What a project. Yikes. I must be getting old…I’m not sure I’d take that on myself. But great find.
Did you get any documentation with it? I only have a nine-page “brochure” which has a lot functional detail in it. The EQ is pretty great function-wise with the switchable Q on the mid bands, switchable peaking/shelving on hi band and the lo band I’m not sure if it’s natively peaking or shelving but it is switchable to a swept HPF. The EQ performance is supposed to be pretty spectacular.
Congratulations!
That’s a LOT of switches and pots to clean!
Lots and lots of wire too!!!
Since it's not stock, the patchbay is separate. That makes it about the same dimensions as my Tascam M3500. Once I tack on some more frame for the additional channels, I'll put it right where the Tascam is. I'm renting a 2 bedroom house with a huge open kitchen living room area. like 33' by 18'. So the master bedroom is the mixing-listening room and the living room is the live room. The drum set is in my kitchen behind the counters, since that's about halfway in the room. I'm shocked at how much better the bass drum sounds in the microphones in a large room. I even tried putting a breakfast nook bench in front of the kit, which blocked the bass drum halfway up--totally changed the sound of the drum. I've heard bass notes have like a 20 foot long wave form and small rooms don't support bass well. I really lucked out with my old 1915 house. Plus the foundation is settling badly, so none of the walls or floors are perfectly parallel anymore--bonus! haha
Fortunately I'll be able to use it for recording and mixing while I'm slowly restoring it. I'm not a trained technician, I just had to learn the basics in order to fix all the old stuff I buy, so I'll be taking my time with this.
Congratulations!
Thanks for the congrats! Yeah, I wasn't expecting the EQs to have push-pull pot switches. There's a push pull on all 4 EQ bands, I thought that was only on the Elan's and Elites--maybe I was thinking of the adjustable Q on the Elites. I have a binder with all the schematics for every Series III PCB, and the manual. The manual is surprisingly limited. Seems more like an overview of the features and it says nothing about a typical signal flow or how to use the patch bay. I have no information about how the patchbay was wired, just labels above the jacks. I guess depending on how it was soldered, it's either normal or half normaled.
Since the manual is basically "our mixer has these features" and nothing about how to use it, explaining the board must've been the technician's job when the board was commissioned. It's going to be a fun evening plugging a test tone into the patchbay to see where it goes!
