LazerBeakShiek
It is a life preserver
They gave me a number of possibilities. Was it..
A. Something in the way like a wire
B. Foam blocks need to be stacked under the pickup
C. It was a NECK pickup not a Bridge( from Vendor)
D. None of the above
Answer was D.
Bend the tabs. Fixed forever.
This guitar is now way more satisfying to play. A true bolt on tremolo system by Deusenberg that shows no holes, and 20 or so pickup combinations. The $199 Dot/Sheraton II is kinda basic. The 500k tone control caps were stiff with .047 so I took it to .015 and .022 . A little better , on 50's tone wiring. I could have dropped the cap value even lower.
You only want to do a Hollow body once. The pieces need to be fed through the hole with string. Fish em , pulling the string up the hole.
Hey man, I like seeing your projects. What are you working on to bring it to the next level?
Answer was D.
