RueMorgueRecord
ok long time now speak all, but to the point me and my partner are looking into command 8. we are upgrading to pt 9 anyday once it arrives in mail, and are running a mbox2 currently.... now heres my concerns
do you need the mbox 2 to run the command 8, or does the 8 replace the need for the mbox.
also i am looking at pics of the 8 and i dont see 8 inputs for mic/line on the back. am i under the wrong assumption that having the 8 means we could per say mic a drum kit and record all at once each leveled seperately and having seperate track???
~ to add to my concern there, till now i have been running through my analog mixers the mics, then out into the mbox for drums. so my mix was always set after the board and the one track was for the whole kit that had the mix already. we were hoping that those days would be behind us and the above were the case.
is a used command 8 going to be fully compatible with the new PT 9 software?
can really use alot of insight on these things . thanks
