P
		purplepeople
Member
Hi, I'm trying to use Trackspacer to carve some space in some very dynamic instrumentals. Primarily because the bass/kick is very strong and the instrumentals have quite a bit of panning.
How I have things setup sounds ok, but I feel like it could be better.
According to videos and such that I've watched it recommends using the "mid" option to cut space for the vocals. Is this the best option for all situations or only if your vocals are centered mono in the mix?
My vocals are very wide. I have centered vocals, but I also pan layers to 39 l/r, 59 l/r, and 100 l/r. It creates for a very wide sound. Probably around 10 different layers. Sometimes more.
When I'm using Trackspacer, I don't feel like my panned layers are coming out enough in the mix. It leaves the vocals sounding flatter than I think they should sound like. Is this because I have things set to mid instead of L/R? Meaning it's not leaving any room for my pans? I presumed if I used L/R it might crush the stereo/panning sound of the instrumentals?
My computer is super slow and I can't watch the graph/listen to what's happening in real time. So it makes things difficult getting it how I want it.
Currently I have things setup like this.
1. Trackspacer on my bass to duck for my kick. Around 5%. L/R Should this be mid?
2. Trackspacer on a bus with all of my drum elements. I have it setup to where it's only cutting around 3.5-5k. Around 7%. Mid. Should this be L/R?
3. Trackspacer on a bus with all of my other instruments. I have it setup to where it's ducking the whole area. Around 5%. Mid. Should this be L/R?
For this above setup, how should my attack/release settings look like? I noticed the default is too slow on some songs and doesn't properly duck certain instruments if they repeat quickly.
Since I can't listen in real time this is difficult to get right. For my above setup how should the attack/release speed be? And should I be using mid or L/R in each of those setups?
Thanks for your help.
