Need Realy covers for 58 or MS16 channel cards
evm1024
evm1024
I've been replacing the relays in the 58 and discovered that I do not have enough metal covers for the relays. I like to put them in as that they give a little noise immunity when the relays switch.
I'm at work right now and think that I need 6 or perhaps 8. So if you have any dead channel cards pull those covers off and let me know what you want for them.
Other mods to the channel cards other than replacing the relays are to replace the bias coupling cap, put sockets in so that I can replace the opamps (only need 3, the meter driver is OK) and change out a cap or 2 when I get around to it.
thanks, Ethan
manufacture them :)
no clue what exactly you are talking about, but based on my "imagination" ;)...
Maybe use some soft metal/heavy-foil-like (coffee can comes to mind heh heh ) , cut out, make box so it fits the relay under with "mounting flanges", you can wrap tape around the box to keep it together, seal the "joints and for extra "sound-proof" :), and then you can super-glue them on to the board, or mini-screw on... :drunk:
