Blue Bear Sound
The way I typically use Cubase (SX) is as an audio editor with tracks being dumped to/from MDM machines....
Essentially, with this usage, tempo in Cubase is an irrelevant concept... but according to the manuals there is some difference in resolution when using linear vs. tempo-based audio tracks....
When you create a new udio track, it defaults to tempo-based.... but i'm not so sure that I shouldn't be converting them all to linear time-based (since they are intended to sync with external machines that are time-based also....
For those of you using Cubase in a siimilar fashion - any comments??
