R
rightroad1
But I think you can also consider the AMD Athlon 64 X2 6400+ 3.2GHz 2 x 1MB L2 Cache Socket AM2 Processor .
Looks good. With the P35 chipset you can wind up the fsb to 1333MHz.
Only thing that stuck out to mw was your hard disk.
For the same money, you cant get a 400GB unit at newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136068
It's two drives......
Less internal heat being generated, less wires, more space. Unless you planned on using one to backup the other, or are running a RAID 0 or 1, in which case, is a great idea.
I would get a vid card without a fan.
I don't see why it wouldn't be stable as heck. Core2Due is really awesome right now. The 775 board may be upgradeable for a pretty good while ahead too. And that GPU fan may be unnoticeable anyway. Some of them don't ramp up speed unless in 3D applications. That server case looks a little scary to me, but as long as it fits your needs. How do you access a CD drive?![]()
carp dude, thats alot of money for a P35 chipset board. I'd have gone with th eIntel board like I originally was talking about. For that kinda jack, we have the new X38 boards coming in like next week, which have improved PCI resources which would be nice for your Magma chassis.
That case has 2 housings inside of it for various 5.25" devices. There are 2 3.5" bays for hdd's in the middle vertically and one 3.5 below the drive bays on the right side of the case. Its a pretty easy case to build in to and is definately road worthy. Just make sure to attach the support bar for extra rigidity.
As to video cards (for anyone who may be looking in the future) the 8600GTs come in fanless versions from several manufcturers now, and give you dual duallink DVI as well as Dx10 compatability with Vista for future use. Other cards such as the 8400 are also available fanless with fewer features and less memory for less money.
I'd highly suggest an Intel P35 board and an E6550 processor. Your cost will be nearly identical to that setup. Current performance will be slightly better on the Intel with real world audio usage, and your upgrade path is wide open. With the AMD, you're pretty much at end of life cycle on that chip and board. Its really better all around. And for stability, we've tested it with 2 HDSP MADI and 3 UAD cards (as well as every combination you can think of) and its proven rock solid.
http://www.adkproaudio.com/benchmarks.cfm
Yes! I got the P style board with the 1333mhz FSB, and the 6750 Core 2 Intel.
But make sure you get the absolute fastest FSB and the absolute fastest memory to match it. For example, dont get a 1333 FSB and then get cheaper 333 or 800 memory. We are only talking about an extra $50-100 bucks here, but the advantage in your recording will be huge.
Think about it. Why do you think every major recording suite has a cpu meter to tell you when you've maxed out your cpu cycles?? If you want more freedom of choice and freedom of expression in your mixing with tracks and plugins and stuff, then the ONLY way you can get it is to get the fastest board FSB and the fastest memory and the fastest SATA hard drive you can possibly afford.
I went from buzzing my cpu frequently on my old Athlon cpu, to never even seeing the cpu meter move above 10% now, and I'm running a grand piano modeller and plugins on every track, etc.... It is well well worth the extra money!
