F
FingerzAndKeyz
Member
I'm not sure I understood your last post, but I hope so. If not, disregard my attempts within this post...
I'm not sure of your expertise in such things, but LEDs have a + and -. If one is coming on when you think it should be off, it might be that the polls are reversed. I'm not saying this is true, but just double check. I know manuals with motherboards are very cryptic, mostly because they are usually translated into English from Chinese, or Taiwanese (is that the same thing?). Many motherboards have the + and - etched where you plug these LEDs in. Sadly, sometimes it's just trial and error to get some of these lights to work. + wires are suppose to be the ones with a line on the insulation, if you're lucky. One test would be the HD activity LED. Of course, it should light when the drive is accessed. And the power LED should be on when the computer is on. If you get the opposite, you then know how + and - are suppose to be labeled.
As for those LEDs that show if the power on tests are OK, I've never seen a motherboard that didn't give you a beep code when something was good or bad with the power on test. But, I guess things do change. Why include an on board speaker or tone generator for those beeps, when you can do the same thing with some cheaper LEDs. The good thing about the beep code is you can hear it, when the case is on. Ah, progress!
But, as for those LEDs on the motherboard...they are hard wired, so they can't have the + and - reversed. I'd check the manual to see if you can figure out if it's good when they are on or good when they are off.
