NL5.. A couple of weeks ago I was wandering aimlessly in your shoes. I spent a rediculous amount of time in this forum (and others) pondering which components to purchase. The build posted below is running great. It's been able to handle everything I've thrown at it thus far. I chose the motherboard listed below for several reasons, one being the fact that it used the Texas Instruments chipset for the firewire. It also has a very user friendy interface for the bios. I opted to install both XP and Vista. (They are on seperate drives) I went a little overboard on the video card. I am by no means an expert, so I may have made a few mistakes. I hope the folks in here will shed some light on them if need be. Good luck!
1 Antec Take 4 Blue 4U Quiet Rackmount Server Case - Retail
Item #: N82E16811129023
Return Policy: Limited 30-Day Return Policy
$269.99
1 EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130082
For Tech Support 888/881-EVGA (3842) $289.99
2 Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822148140
This item is serviced by the SeaGate. Please call 800 -732-4283 for service. $169.98
1 GIGABYTE GA-P35-DS4 Rev. 2.0 LGA 775 Intel P35 ATX Intel Motherboard - Retail
Item #: N82E16813128064
Return Policy: Limited Non-Refundable 30-Day Return Policy
Gigabyte (626)-854-9338 option $169.99
Track
1 Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 Processor Model BX80557E6750 - Retail
Item #: N82E16819115029
Return Policy: Processors (CPUs) Return Policy
Intel (800)-628-8686 Please Verify Processor matches order Prior to installation. IMPORTANT: Always pack you CPU well for return. We will refuse your RMA if we received it as DAMAGED! $194.99
Track
1 Arctic Silver 5 Thermal Compound - OEM
Item #: N82E16835100007
Return Policy: Consumable Items Return Policy
$5.99
Track
1
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM
Item #: N82E16832116202
Return Policy: Software Return Policy
Please Note CD keys are listed on the outside of the plastic wrap accompanying your product. $111.99
Track
1 Microsoft Windows XP Home With SP2B 1 Pack - OEM
Item #: N82E16832116056
Please Note CD keys are listed on the outside of the plastic wrap accompanying your product. $89.99
Track
1 Athena Power 4pin (P4ATX-12V Male) to 4pin (P4ATX-12V Female) Extension Cable Model Cable-AD09 - OEM
Item #: N82E16812198005
Return Policy: Standard Return Policy
$2.99
Track
1 SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
Item #: N82E16821103116
For Sony Monitor Support Contact: 1-866-357-7669 for all other products contact: 800-222-7669 $7.99
Track
1 ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Item #: N82E16835186134
$19.99
Track
1 LITE-ON 20X DVD±R DVD Burner with 12X DVD-RAM write and LightScribe Technology Black E-IDE/ATAPI Model LH-20A1H-185 - OEM
Item #: N82E16827106055
$35.99
Track
1 Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK - Retail
Item #: N82E16820220144
Return Policy: Memory (Modules, USB) Return Policy
$92.99
Subtotal: $1,462.86
Tax:
$0.00
Shipping: $43.41
Amount Paid: $1,506.27
