Nady tube mic tube mod question
  • Thread starter Thread starter Meej
M
Meej
Hi all,
Me again; my second post.
Can anyone help change the tube in this mic? How does does this thing come apart?
Thanks!!
unscrew the bottom and slide the metal housing off. if the tube is socketed, it's pretty easy-- just negotiate the old one out and put the new one in. it will take a little bit of effort so be careful about bending the pins. if the tube is soldered in, it's a bit more complicated.
There is a rubber cap that hold the tip of the tube in place, which is supported by a plastic retainer. You can lift the bottom of that retainer up (it's spring loaded) and tilt the tube at an angle to get it out. It also helps to loosen at least one of the screws that hold the socket base.
