D
Descalabro
Hello.
I entered the world of recording this year, at home, with the following equipment:
Jackson Dinky guitar (around 500$);
Seymour Duncan high output pickups (around 300$);
Metal Muff Pocket distortion pedal (around 50$);
Vox Amplug AC 30 (around 30$);
HP Pavillion DV9000 laptop (around 1600$, but used for many other things);
Setup:
Jackson Dinky -> Metal Muff -> Vox Amplug AC 30 -> HP Pavillion DV9000 (Nuendo 3.2)
Now, the type of recording I am after is a very heavy guitar sound, with lots of distortion, to create something people usually call "a wall of sound", but with enough clarity to be an pleasant listen. This is what better suits modern Doom Metal, which is what I play.
On my first attempt I used a mono track in Nuendo and a high level of distortion on the Metal Muff. The sound came out very concentrated and it had too much fuzz, even though it sounded heavy. I felt like I wanted a wider, more evolving sound.
So I lowered the distortion on the Metal Muff and added some more distortion on the Vox Amplug, and recorded on stereo, twice, with a guitar for each side (left and right). With a bit less distortion and a widened sound I was able to pull off a sound quality comparable to many studio Doom Metal bands, but still not as good as the best bands, like Esoteric or The Prophecy (UK), and I still didn't have the desired volume levels of most of the genre albums.
Also I have a problem with the Vox Amplug AC 30: even though it is a good replacement for the enormous output levels of a real amp, it has a background "fffffffffffffffffffffffff" which I cannot remove.
So I decided to order a Presonus Firebox from Ebay and try to record with my Fender Frontman 212 R (also I was recording my guitars without any sound besides the natural string sound because of latency on my pc's soundcard).
I know this is a noisy amp that belongs to the cheapest of the Fender lines, but at least I hope to remove the "ffffffffffffffffffff" I had with the Amplug if I am able to keep my cables clean from moisture.
And this is where I have a question:
Will I need a Direct Box when I have the Firebox?
Thank you for reading. All opinions are welcome.
(I can send any recording demos if you wish)
Setup:
