philbagg
Just Killing Time
Hey Guys, been away for a while. How ye doin
Got myself a new guitar, she's friggin' sweet
(pics below)
Ibanez S 670. Plays great, low action, amazing tone (especially the clean tone), Ibanez ZR (Zero Resistance) floating bridge, 2 humbuckers & 1 single coil with 5-way pickup switch, one tone & one control volume, and durable outer-casing to prevent fall-apart
D)... Not to mention, this is one of the skinniest guitars I've ever seen, and weighs about half as much as what I'm used to, without losing any sustain. The top edge of the upper horn for example is only half-an-inch thick!
Oh, and Elixir Strings kick ass
So, 2 reasons for this thread: 1) To show off
, and 2) I have a question about tuning this thing with regards to the tremolo bridge. This is the first guitar I've ever owned without a fixed bridge.
At the moment, the guitar is in D standard (and the bridge is level with the body), but I want to tune it up to Eb standard, and maybe E standard in the future. I understand that different tunings change the string tension, and will therefore have an effect on the bridges position. I believe that with any usual Floyd Rose (etc.) bridge, you'd have to open up the back and use a screwdriver with the springs in order to alter the bridge back into place. However, this guitar has a turn-wheel on the back that can be moved by hand, and has "String Tension" written above it, eliminating the need for screwdrivers and spring adjustments.
I'd imagine that what I have to do is:
1) Unlock the nut
2) Put the fine tuners (bridge) back to their middle-position
3) Tune to the desired tuning
4) Lock the nut
5) Turn the "String Tension" wheel on the back until the bridge sits parallel with the body again.
Am I missing anything? Probably sounds stupid, but I don't wanna mess up anything with this guitar. I believe a lot more care needs to be taken when dealing with a tremolo bridge.
Oh, and one more thing, have any of you ever (or heard of) broken a tremolo bridge from doing, let's say, shitloads of divebombs etc. ?
Is it easy or hard to do?
Here she is:
Cheers guys!
(pics below)Ibanez S 670. Plays great, low action, amazing tone (especially the clean tone), Ibanez ZR (Zero Resistance) floating bridge, 2 humbuckers & 1 single coil with 5-way pickup switch, one tone & one control volume, and durable outer-casing to prevent fall-apart
, and 2) I have a question about tuning this thing with regards to the tremolo bridge. This is the first guitar I've ever owned without a fixed bridge.At the moment, the guitar is in D standard (and the bridge is level with the body), but I want to tune it up to Eb standard, and maybe E standard in the future. I understand that different tunings change the string tension, and will therefore have an effect on the bridges position. I believe that with any usual Floyd Rose (etc.) bridge, you'd have to open up the back and use a screwdriver with the springs in order to alter the bridge back into place. However, this guitar has a turn-wheel on the back that can be moved by hand, and has "String Tension" written above it, eliminating the need for screwdrivers and spring adjustments.
1) Unlock the nut
4) Lock the nut
??Am I missing anything? Probably sounds stupid, but I don't wanna mess up anything with this guitar. I believe a lot more care needs to be taken when dealing with a tremolo bridge.
Is it easy or hard to do?Here she is:
Cheers guys!
