Hi Joey,
Thanks for checking back. I just peeked over here, to see if anyone had added any tips, or anything, and there you were!
So, I am currently using Tracktion 3 (Mackie/TAPCO), Tracktion 2 came with my interface, and after tinkering with it a bit, I found it to be much easier for my brain to grab a hold of what was going on, than with the previous DAW I was using (SONAR HS 7XL). Before, I tried to understand about sending and buses, but I was getting confused.
The Tracktion software has a little icon, "new filter", and you just drag and drop it on the track you want to apply any, of a number of, effects, etc. Then you can adjust each parameter of the effect individually, or use the preset (which I did for the piano).
Reverb has been a tricky thing for me, for a long time. Before, when I used dynamic mic's and audacity for stuff we wanted to record, I found that audacity came short in its effects. That was one of the main reasons my hubby let me invest in some better equip/software. We have (in the past) used a Mackie mixer in the recording chain, in order to get the right reverb effect for a friend of mine, but I was hoping I could achieve the same end, using my new stuff, and Tracktion 3.
I had a thought today, about just taking my raw vocal track, and adjusting each parameter + and -, while it is playing, in order to really understand what each parameter does to the track. I haven't had time to do it yet, but I think you said a key point that I was hoping to avoid: It takes a lot of TIME to master this stuff. I am hoping to invest ENOUGH time, in between recordings, to improve every time, but I know I also need to be patient for my brain to soak in all I'm learning in the process!
Is there another effect that would help me achieve a soft, natural effect on the vocals, besides reverb? (I do realize it won't remedy my pitch prob's, but I have a friend who is a very strong lead, and I want to have a better approach for her sake!)
All the best to you, and anyone else who feels like pitching in...
