Nate74
HR4FREBR
I think this should be an upgrade that I can handle and do for less than $100, but before I try it, I wanted a little guidance.  My google searches yield either nothing, or too much information and it doesn't seem this specific setup has been discussed here before either.
I have a white box PC that I had a local guy build for me about 18 months ago. At the time I had him put 1Gb of RAM in it (2 x 512MB), but he told me I could easily upgrade to 2Gb in the future.
The mainboard is a Biostar P4M800 Pro-7 and the manual states:
DIMM Slots x 2
Supports DDR2 400/533
Each DIM Supports
256MB/512MB/1GB DDR2
Max Memory Capacity 2GB
Singer Channel Mode DDR2 Memory Module
Registered DIMM and ECC DIMM is not supported
Also from some articles I've read, the FSB number may be important. The manual states:
FSB 533/800/1066 MHz
So my question is, what of this information must match? and What else do I need to be aware of?
Thanks in advance!
DIMM Slots x 2
Each DIM Supports
Thanks in advance!
 Even if you don't wanna buy Crucial sticks of RAM it will give you all the info you need.
