evm1024
new thread option
I will post a photo when next I come across one. In general thy are not easy to spot. They form a hairline crack that circles the wire or pin that is soldered to the board. Close visual inspection will show them but if you do not know what you are liiking at you may not see it for what it is.
Touching the joint with a probe may or may not cause the circuit to work again.
I generally have a dead channel and by doing a bit of logic can figure out where the cold solder joins "should" be. My last one was on a 34B repro head channel 3. Sync playback was OK so somewhere from the head to the output....
--Ethan
SteveMac said:Yes, please post a pic EVM when you find one. Are they easy to spot?
--Ethan
Most of his clients send him stuff by courier from hundreds to thousands of miles away. He's got a very large clientèle because he works on all the Major brands...I've seen Ampex's, Studer's, MCI's, Otari's, Sony's and even the occasional Mitsubishi DASH monster on his bench.
