Toki987
Rock Steady
The other night while pluggin a patch cord into the recording out on my Fender bass head, it lit my ass up. Felt like 110 volt ac. What would cause that?
Toki987 said:The other night while pluggin a patch cord into the recording out on my Fender bass head, it lit my ass up. Felt like 110 volt ac. What would cause that?
apl said:I found some old Fender amp schematics, and sure enough, the switch picks which side of the outlet is chassis ground, through a capacitor. So you could easily set up a situation where your amp and the other equipment has a big voltage difference.
easychair said:The ground switch reverses the polarity of the AC. The polarity of the AC in the amp and PA must be the same, or you will get shocked. The amp AC is swinging positive while the PA AC is swinging negative if the AC is reversed in the amp. Your lips provide a connection for current to flow between these opposite voltage potentials.
The ground switch stayed to protect people from shitty wiring.
ggunn said:The operating phrase here is "through a capacitor"; a 0.05 microfarad cap is pretty much an open circuit to 60 Hz. The effect of the difference in that switch position is minor - it means that you either get a mild shock or none at all when you touch the amp chassis and an earth grounded piece of metal at the same time. If you get a major shock, something else is wrong.
In any case, the OP said that he was plugging into the "recording out" of the Fender head, which implies to me that it is a newer design. Check me on this, but I believe that that grounding switch went away with the advent of three conductor (hot, neutral, ground) power.
FALKEN said:oh man.
I was playing at a club about 3 months ago and every time my lips touched the mic I got a small shock....
of course I didn't know this until we had already started our set, so I just finished it out...
I suspected a bad mic cable at the time.
Never once happened at practice though.
punkin said:I see reference to ground through out the circuit diagram but from the power receptacle side I don't see the connection. The chassis ground should have a connection to earth unless by some weird design, they want it to float...that would simply be nuts since everything else you might make contact with will be earth ground.
That switch is kinda strang but with that capacitor on there, all it's doing is selecting which leg of utility to add a little decoupling/filtering to. Perhaps an attempt to remove a little excess hum or noise. It's not switching polarity.
