Multimix16 f/w setup
  • Thread starter Thread starter tribal
T
tribal
Hi, I have a question about monitor speakers and headphone amp, For monitors should I use main out or control room out? with my behringer HA8000 where should I connect into, Aux sends,return, control room out!?
Ta,V
manual...
has lots of information regarding setups, including diagrams. it's worth a read.
I did read the manual a couple times and I am using ctrl room for my monitor and aux sends for my head amps. What I want to know is that when I record my vocal sound is too flat I like to hear it warm,reverb etc sound so that I feel confidence about my voice. Please guys if you know what I am taliking about share me your thought or idea. I'll list down what I got below so that you understand better I hope..
Ta,Van
Multimix 16 firewire (Alesis)
Behringer HA8000
Alesis Midiverb 4
Rokit monitors
Alesi Micron
From the Alesis web site
I would like to route audio from the computer to the MultiMix, apply the MultiMix’s EQ and digital effects, and then record this audio back to the computer. Is that possible?
This is possible, but it requires some additional cabling.
1. Turn the HEADPHONE/CONTROL ROOM volume knob all the way
down.
2. Press the 2 TRACK TO CONTROL ROOM button down, and leave
the 2 TRACK TO MIX button up.
3. Take a pair of cables, and connect the CONTROL ROOM OUT jacks
into a line-level stereo channel’s input jacks.
4. Connect your speakers to the MAIN MIX OUT jacks.
5. Slowly increase the volume on the HEADPHONE/CONTROL ROOM
knob until a good signal level is reached on the line-level stereo
channel chosen in step 3.
6. EQ the stereo channel to taste, and dial in the right amount and type of
digital effect.
7. In the computer, record the MAIN mix.
Note that you can only route two channels from the computer back into the
MultiMix this way. No more than two channels from the computer are ever
available to the MultiMix :)
Hey Tarzan thanks for the info tech. I'll see what happen on Sat..
Cheers,V
