R
Robert D
I like multiflavor dynamic shakes, but a lot of people abuse them and just start drinking them with everything, expecting to make a crappy hamburger taste better.
EddieRay said:An observation:
One of the frequently asked questions I see here is how to get final mixes up to commercial CD volume levels. The usual answer is "have it mastered".
When pressed further about what occurs in the mastering process that accomplishes the higher volumes, the usual answer is multi-band compression.
I just picked up CD Architect which has an MBC plug-in. I really have no clear idea how to use it but I'm experimenting with it, mostly by compressing the frequency ranges which seem to be most prominent in the mix. Can anyone suggest a better approach?
Personally, I'd have two questions for Mr. Clearmountain (man, it'd cool if he were actually here to answer them...then we'd REALLY have a threadRobert D said:Bob Clearmountain in a 2004 interview;
"Occasionally, a piece of gear comes along that fills a certain need that I have. An example is the BSS dynamic equalizer. I always wanted a box that would compress or limit certain frequencies, so when a frequency gets harsh, it will be sensitive to just that.
I'd really like Glen and Massive to speak to this.
.) My first question would be where is that harshness coming from/how'd it get there in the first place? The second question would be, how is it that it's only harsh once it rises above a threshold; is the level changing the timbre somehow?I never said that. I said that if more people would learn proper fundamental engineering technique, that the NEED to use one would be virtually non-existant.Robert D said:I respect each of your personel opinion that band specific compression is not for you, but I will continue to take issue with your oft stated contention that no one else should use it either
SouthSIDE Glen said:My first question would be where is that harshness coming from/how'd it get there in the first place? The second question would be, how is it that it's only harsh once it rises above a threshold; is the level changing the timbre somehow?
As to the first question, the followup is why couldn't it be nipped in the bud instead of fixed downstream?
G.
Awww, RAK, you stopped just when it was getting goodRAK said:Sometimes that's just the way the vocalist sings. They may have a little harshness in certain frequencies, that a dynamic EQ can help smooth out, and you can't "fix" someone's biology. (well maybe you can, but I'm not getting into that)
.SouthSIDE Glen said:Awww, RAK, you stopped just when it was getting good![]()
Ok, let's say that were the case. Is that something you'd wait until mastering to fix? I'd have to say no.
G.
Hahaha, and I respect you for it, Rob. (Bob? Robert? RD? Horatio? Mr. D.?Robert D said:That's my story, and I'm stickin to it, dammit.![]()
I think the Law Of Unintended Conesquences is the paramount issue here.flatfinger said:Really, debating wheter people can handle the application of a tool ( which in this case seems to be the exception, not the rule) and that since the result often runs amok seems to ignore a more pertient question....... does it sound good when applied properly?
SouthSIDE Glen said:Mixing itself is disappearing. I don't know if its from lack of understanding on the part of the new batch of rookies coming along, or whether it's sloth, but for some reason in the past decade or so the belief that throwing gear at a project in the mastering stage is not only the easy way out of having to do the job in the tracking and mixing stages, but in fact how things are done and have always been done, has spread like a disease. And production quality is suffering because of it.
G.
How do you know this ?SouthSIDE Glen said:9 out of 10 people on this board use MBCs to mix their songs after the two mix is complete and they should be mastering, instead of actually mixing their stuff when and where they are supposed to. The average 2006 HomeRecc'r's idea of "mixing" is to compress the shinola out of every track, lay the tracks on top of each other like sheets of plywood, mix down to stereo, and then use the MBC in mastering to try and fix the fact that their mixes sound like shit.
After almost 30 years of working with associates and clients in this racket and of doing this stuff onesself both as amateur and pro, and after over 3,000 posts in 18 months on this forum, one tends to learn a thing or twoKeiffer said:How do you know this ?![]()
You often use very wide brushes when painting pictures...
. Please explain to me how it is that people were able to get past these problems just fine long before MBCs came along?Keiffer said:there are some circumstances that call for MBC... here's several that come to mind.
Helping certain instruments sit in a mix better. One can track all day long and hope the tracking is perfect, but as the mix comes together, MBC may be the perfect tool.
One is handed a set of tracks to mix and MBC will do a better job than EQ on a track
Distorted guitar bottom taming (close micing and proximity affect)... It's often virtually impossible to tame the bottom via micing w/o killing the tone
SouthSIDE Glen said:too many are trying to be an engineer overnight, and are thinking that sophisticated technology will let them do that fairly automatically. Then they come on here and ask a) why their mixes suck, or b) what's the best setting for using technology X.
To a) the answer is because all the fancy gear in the world isn't going to help them if they don't know technique first, and to b) the answer is that they are asking the wrong question to begin with.
I keep repeating this, but it's just not getting through. I'm not blaming the MBC. I'm blaming the mentality behind the belief that it's a necessary tool.
G.
I fear I may only have succeded in painting myself as a geek. And an idiot. Oh well...such is life...A very similar analogy that I keep in my mind is martial arts training.legionserial said:If only recording was more like dungeons and dragons.
