promesis
Black Knights of the 4H.
I have a MOTU 896 just hanging around and need some additional mic pre's. I already have 8 mic pre amps but another 8 channels are going thru my Mackie 32/8's mic pre section - I would much rather not use the Mackie's pre amp section .. I am going into an Alesis HD24 .. I was thinking of using the MOTU 896 as an additional 8 channels of Mic Pres and use the Fibre Optic output of the MOTU to go directly into the fibre optic input for channels 9-16 on the HD24. Last nite I plugged in all of the mics into the MOTU but no levels came thru on the Analog Input level meters.. I did not have the fibre optic cable in - just thought I would check levels .. but like i said - there were none.
Ok.. do I need to have the MOTU hooked up to a computer before the signal will pass from the Mics into the pre-amp section? Or simply - is it possible to use the MOTU just as a mic pre.. without any computer interface? Do I need to have an output connected to the MOTU to get the mic signals into the preamp section.. what's up with this thang? Any help is greatly appreciated.
