mosfet amps
  • Thread starter Thread starter mr engineer
M
mr engineer
i might me getting hold of a mosfet powered amplifier custom made for village roadshow company.....
does anyone know if mosfet amps are alright/good for monitoring?
Cheers,
Daniel
Four things to check out:
1 - Make sure the power rating on that amplifier is in the same ball park as your monitors.
2 - Find out what impedance load the amplifer is designed to drive (2, 4, 8, 16 ohms), then find out what impedance your speakers are (probably 8 ohms). If they match, you're okay.
3 - Some amplifiers are purposely designed with a non-linear frequency response, that is, they accentuate certains frequencies because of what they are used for (guitar amps are a good example). If possible, find out if the frequency response is fairly flat. For monitoring purposes it is essential that the amplifer not hype any particular frequency.
4 - The last concern is noise and distortion. Amplifers built for monitoring typically have a very low noise floor and very little harmonic distortion. Your amplifer sounds like it was designed for PA use and probably sacrifices fidelity for power.
Hope this helps.
thanks fo phyl,
i'll look into it...i remember the guy saying it was used for cinema use.
FrankD77
Replies
8
Views
1K
FrankD77
FrankD77
jimistone
Replies
13
Views
974
Sky Blue Lou
Sky Blue Lou
F
Replies
6
Views
854
D
Replies
2
Views
456
sabuilder
