R
Raymeous
Hello there!
A drummer friend of mine was over last night and as we're both new to this whole recording thing (well sort of, I owned a VS840 at one point) we tried to throw up a mic and record the kit. We only spent 10 or 15 minutes on this as he had to go... but hey.
The room is my untreated (yet) music room or "lab" as I like to call it. It's on the second floor, with carpeting and is roughly 10' x 13’. There's a goofy bump out on the north wall due to the stairs and entry door. Along the west wall is my collection of guitar and bass rigs. The opposite wall is a 50/50 split with one half being a wall, and the other portion being a pair of sliding closet doors. The south wall has a large 3'hx5'w or 4'h x 6'w window. My desk is in front of that, while the kit is closer to the north wall and “aimed” at the window wall.
These are 4 year old pic and things have changed a lot, but you'll get an idea of the space.
This pic is the south (window) wall and the west wall:
This one shows the west wall and the north wall with its goofy corner.
facepalm: Man I need to take some new pics)
Now for the good stuff: The Gear!
THE KIT: We used my 5pc Sonor Force 3001 kit with a 22" kick, 10" 12" and a 14" floating toms. The snare is a 14"x5" wood snare. The cymbals were a mix of cheapies. =*( I need more "yellow" cymbals and less "orange" ones.
THE MIC: Rode NT2a set to cardioid, with a -10db pad, with the HPF bypassed. I positioned the microphone about 3 feet in front of the kit, aiming at roughly the spot between the kick and the rack toms, almost at the " T " hardware mount for the toms, but a bit lower. It was hard to tell, as between the minimum stand height, boom arm, and shockmount, I couldn't get it where I wanted it to be. the boom arm angled down and the shock mount prevented angling it back up to be parallel to the kick, but it worked out okay I guess. We only had a few minutes so it was definitely a "good enough" moment.
INTERFACE and DAW:
I used the MIC pre on my Eleven Rack. Bet you forgot it had one of those! I then recorded this into Pro Tools LE 8 (upgrading this week). The levels stayed in the middle to top end of the green range, and bumped up to the mid yellow range. No clipping ever. Nice. The -10db works great.
THE PERFORMANCE:
Using some “Hot Rods” bundle sticks, he just played whatever, but it did kind of sound like "Wild Thing" and I don't mean Jimi. I mean the "ba da dum dum dum" fill from the hip hop version.
THE RESULTS:
I kind feel like I'm cheating you folks a bit for not having a sound clip to play for everyone, but we're supposed to try this again tonight. This time I want to try it again with the SM57 vs. the Rode, just to see the difference. Why? Um, why not? I’m just playing here.
What I can tell you is this. It works!!!
Okay maybe not the greatest, but you could hear everything clearly; kick, snare, toms, cymbals, everything. The kick drum was huge, and sounded good, but in reality it was simply too beefy. It did kind of work with what he played as referenced before, but in general it was simply too much oomph.
I didn’t have the low cut on which could be part of it, however I think the floor was a contributing factor. It’s not the ground floor on a foundation, but the second floor, so I think some of that space between created an acoustic chamber if you will and added to the overall resonance. I figured that it probably would, but I didn’t want to go straight to the HPF. I wanted as natural a reference point to start from as I could get.
This is only the first round with many more to follow. What’s the point you ask? There isn’t one, other than a single mic can pick up the whole kit, so you don’t have to have a dozen mics and a monster interface to record your drum set.
INTERFACE and DAW:
THE PERFORMANCE:
THE RESULTS:
