The sad thing is that Dadhead52 hasn't been back since March of 2022, so we don't know if he's using it or if he decided to take up mountain biking instead of music.
There are pluses and minuses to both interfaces.
Looking at the two interfaces, the Motu beats out the Steinberg in terms of dynamic range/noise floor by 10 to 15 dB according to the specs. I have no way of knowing if that is due to the use of the transformers, or if the basic circuitry design is just noisier. As to whether than extra noise floor is valuable depends on how quiet your recordings are. Rooms and mics can be noisy. There's not a lot of advantage if your base noise floor is -60dB to start with. I know that there are lots of people who think that transformers make "magic" but we all know that just having a transformer isn't going to make or break a recording. However a bad performance will!
I like the option of having metering on the front panel, vs Steinberg's peak light.
Both spec at +60dB mic gain, so it's a tie there.
The Steinberg has internal DSP, so it's possible to do Zero Latency with Reverb, some amp sims and a basic channel strip with compression and EQ. That can be quite handy for situations where you want to do the recording real time and not add in effects later. I have some basic DSP with my Tascam interface, and I have used the internal compressor and EQ to tweak things going in before. It can be a really handy thing, vs having outboard effects or dealing with any latency from a plug-in.
Maybe I'm old school, but I like having a separate power supply vs all USB supply. It seems that most units are going the way of the Motu, with computer supplied power, tho.
In short, they both will work, and offer different advantages. There's a $100 difference in price here in the US, so that might be a factor, but if you're serious about recording and want the options, then the extra money for the Steinberg might well be worth it. In the end, $100 is a couple of pizzas and drinks, which will be gone in a few hours.
If you want budget, then get your Berry Uphoria and use the extra money on a microphone.
