T
tranzmelodika
for the advanced fruityloop user or for those fimiliar with Fl
o.k. ive learnd a new way to mix your vocals into the beat using fruityloops5 or6 right, i got it effected just a little but not quite mastered. THIS WILL HELP ALOT OF YOU OUT THERE. first off the key to mixing is creating a good enough source to mix in the first place say for instance you cant plan on getting good sound quality in a mix recording with a cheap mic, you can but thats when extra effort comes in to play and we all know we dont need all the extra bla bla bla, BUT thats where your wrong mixing can take awhile depending on each individual so you have to be 100% dedicated to creating your best mix becuz when you master the project the laziness will show isnt that AMAZING. you wanna record with a good condenser mic following all the acoustic tactics in your recording space set up it doesnt need to be to professional remember youre only recording a demo if youre not already in a million dollar studio cuz thats where you wanna be right...O.K. the trick is get youre clean vocals exported somehow to wav. export your beat as well to wav. when youve got all your tracks into wav. some how get FRUITYLOOP6 but 5 will work 6 has just a little more effects though you can nowadays DOWNLOAD all this from LIMEWIRE 4.9 open fruityloops at the very topof the menu in between edit and view click CHANNELS the selected the add one option and add about 3 audio clips once youve added those click on the audioclip tab in your browser and where it gives you the option to insert the file that channel will use labeled SMP insert your vocals wav. file now you have 2 more audio clips to add that is your wav.beat twice once youve added your VOCALS plus 2 of the same beat open the playlist and in the bottom as usual draw the files onto the playlist which should be 3 long wav files on top of each other then select the right channel for each the first being the vocals the second being the beat the third being the beat#2 PAN beat1 into left or right then pan beat2 into the opposite of beat1 IN FL this gives you a huge emount of emptiness in the middle to fit your vocals right in plus with effects you cant go wrong the effects are up to you i usually use the waves plugins BUY them or download them WAVES DIAMOND BUNDLE, WAVES MASTER BUNDLE and walla!!!!!!!!! easy mixing/professional
