M
mindsound
Hi folks,
Here is a mixing trick I like to use for a better snare sound and that I share with some of you that may not know it.
When I have a room mic for the drum (added to the other kit'mics), most of the time, as you bring the room fader, there is always a sublte comb filtering effect. We think at first that it's the room sound blending with the direct sound. But it have lot to do with the phase coherence. Even if your room mic "seems" in phase with the snare and overhead mics. What I noticed, most of the time is that as you pushed the room fader, something happen to the mids (and even low-mids). The mids doesn't sound as tick as when the room mic is not present.
Remedy: phase alignement plugin. With this plug you can delay by few ms the signal and more, you can rotate the phase (360 degree if you want). Juggling with these 2 controls at the same time, you will hear your snare sound changing dramatically....to the point that you can get back your low-mids and mids of the snare into the mix. It's as if you were tweaking the room sound. So, you end up with a snare that have more dimensions (thanks to the room mic) but improving at the same time his tone. If not improving, it could be also for finding a new tone that suits better the mix. For sure, it's a micing issue as well, but even when you're 100% happy of your drum micing, there is always more you can get in the phase domain.
You can even transfer that concept to reverb channels. Sometimes, placing a phase alignement plugins after a verb plug, may improve the 3d of the verb and his tone as well. It can even makes the dry and wet sound merging better. It is subtle....but as you know it, a mix is made of a lot of subtle elements brought together.
