A
a2n3d7y
Ok I'll TRY and keep this simple.
I have been a home recordist for about 16 years now and I'm always trying new techniques. I actually don't really like sharing my techniques with strangers unless they share theirs with me but in this case I have a crucial (I think) technical question and can't find it spacifically adressed anywhere on the www.
My question is regarding mixing stereo room mics with their close mic'd source subject.
For example:
(what I've done in the studio for this may seem like overkill but so far the results sound amazing for what I'm trying to do...which is make my bands demo sound like it was performed live in the same room so that the listener may enjoy a more realistic listening expierience.
What I did was record an extra stereo room track for every instrument that was individually tracked.
I used Cubase SX 2.01 and have 2 Echo Mia sound cards installed which gives me 4ins and 4outs. Obviously not enough inputs to record a full band and still have controll over everything in the mix. My SR2404 Mackie has the inputs but Im pretty poor so have limited mics. 1 CAD condenser, 2 SM57's (which I used for stereo room), and an AKG D112 (Im the drummer with all the equipment but I mostly make electronic computer music you know? So I don't spend the good money on good mics really.) SO everything was tracked sepperately 1 take after another.
Anyways....the question!
If I tracked each instrument seperately (guitars and bass) with the exact same mic placement (left the room mics where they were for all basic tracks and put each amp in the same place facing the same direction for each take) how should I set the POLARITY of the stereo room tracks?
I still have controll over this since I recorded digital and can easily reverse the polarity of the specified recorded tracks.
The amp roughly 2ft away from and facing into a corner of the room (2 conrete walls, the other 2 walls behind are drywall) with the stereo room mics directly behind and above the amp (about 7ft back) facing the back of the amp and concrete walls (90 degree directional offset). The front of the amp is also close mic'd. The close up mic is generally mixed higher using the room as a subtle ambience. The true beauty in this is that the room we recorded in is the same room we always reherse in...so its the room we're used to.
The Problem I have is that while viewing the audio tracks on screen the room mics and their close mic'd conterpart are 100% out of phaze. If this is true I can easily flip the polarity of the room tracks and its fixed. But while listening to both options I hear no major difference in the sound at all. And also while doing some simple phaze testing (mono the main mix and if the signal level reduces drastically then you're out of phaze) I found nothing wrong.
So should I flip the polarity of the stereo room tracks?
Or mabey even simpler...
If you recorded the front and back of an amp would you reverse the polarity of the mic behind the amp?
But my case IS different because the mics behind the amp are also recording the reflection of the front of the amp off of the concrete walls.
Thoughts? Sugestions? Criticizm? Anything PLEASE?
There might not even be a problem.
For example:
