Synkrotron
If I was starting out afresh and know what I know now I would take the following route:-
Purchase two Behringer Ultragain Pro-8 Digital ADA8000 which is an 8 channel ADAT A/D converter which will give you a total of 16 channels. You could argue that the mic pre's are not the best but if you're on a tight budget then you need to make compromises somewhere. You should be able to pick up two units for $460 or thereabouts.
Ultragain
And then you'll need a suitable audio card with ADAT cabability and I would recommend the RME Hammerfall Light DIGI9636 which you can pick up for around $400.
DIGI9636
If you don't have any DAW software then I'd recommend Sonar 5 which costs around $300.
You may then decide that you need some mastering software. I'm currentley getting into Sound Forge 8 and with that you get bundled a package called CD Architect which is used for burning your masters to CD. That costs around $270. In the future you could purchase some of the higher quality plugins but for now you could probably manage with the plugins that come bundled with Sonar and Sound Forge.
Well... so far that comes to $1430 so I guess that's not much help... and you haven't even bought the cables and such yet. But... it's food for thought and give you another option to consider...
andy
Ultragain
DIGI9636
andy
